error while installing corona renderer for 3dsmax 2024
corona renderer 10 hotfix 1 and 3dsmax 2024 was working fine since last night. today when i opened the scene i got a license error. i checked my licenses are valid till 2024. so i tried updating corona renderer to hotfix 2. now corona is just not installing ta all for 3dsmax 2024.
i made a complete uninstall of corona renderer from my pc by removing leftover files manually also.
when i used typical while installtion it installs correctly but doesnt install for 3dsmax 2024. when i click on custom and select 3dsmax2024 it gives theattached error. i have tried everything but its just not installing.
reinstalling max 2024 is a big issue and my last resort as i have tons of scripts that need installation in 3dsmax and it takes me atleast 2 to 3 hours do to that.
can someone help why i am getting this error. corona was working fine till last night. i ust opened the scene today and problem started
since your issue is related to licensing and not being able to install Corona, it would be best if you can send us a ticket stating your issue. You can start a ticket using this link: https://support.chaos.com/hc/en-us/requests/new
You can also try installing Corona manually. Here is how: https://support.chaos.com/hc/en-us/articles/4526313794065-How-to-install-Corona-manually-using-the-unpack-files-option-
