Hi can anyone help me with this scene
i cant seem to get rid of the fireflies from the street lights, rendered for 4h34 and reached 81 Passes at PT4 and HD 1024, lights multiplier at 10 and MSI at 400
- Disable HD cache.
- Use PT+PT.
- Show your settings.
- Are those lights IES?
Okay will try that, no they are just regular Rectangle lights
Are those lights in lamps occlude by some kind of glass?
What kind of glass are you using for windows?
What is your lights samples multiplier?
I get that kind of noise on some scenes when I use both Corona Lights and emitter materials. Try and see if the noise goes away if you disable the emitter in the material. It may not solve your problem but at least you would know the cause.
Thanks tried it but still roughly the same, lights take a very long time to converge
Hello nehale
the material of the road ?
Greats
Raf
Is there any reason why the emmitter material is refractive (with real caustic generating refractivness) and reflective ?
Yes, you´re right..
nehale, turn off reflections and refractions, it´ completely useless.
I wonder about that contrast setting.
that reminds me of my green house exterior night scene i had the exact same problem with noise and lights even after many hours of rendering with pt+pt
Yeah sure thats true, but the emiter material is not the problem, even if i switch it off the regular lights will still take ages to clear up, i was wondering though, does the light size play a role though?
Which one is it? I will buy the scene and try myself
Link straight to the Evermotion store would be perfect
Here it is, i just used converter and added lights http://www.evermotion.org/modelshop/show_product/scene-02-archexteriors-vol-08/507/0/0/0
I think i may have found my mistake, looked at the original scene again and see that i just used a dome with a texture for ambient lighting as they did, but now i put the texture in the environment slot to see how that clears up, started render and looks promising now after deleting the half dome/sphere, will see after an hour or two
Hello nehale
you can attach the slot material (setting)
road and
external wall of the building?
Thank
Raf
WOOOOW, thanks you so much for those tips and this is the best corona exterior render i have seen thus far
ahahaha Rawalanche … you’re a Genius
