Every time I press the render button - vfb ocio corrections are canceled and the srgb is shown
Very annoying. It also seems in the latest builds - rec709 does not work, only rec709 d60.
edit
reinstalled vray and rec709 works. speechless…
Devs are looking into the first issue as we speak, ID for this issue is VMAX-11309 ,I will update the thread when it is solved
It is not a new issue, it first appeared in update 1
About the second issue, please make a separate thread in the GPU section or Phoenix one, I will follow along with the Phoenix team to see what is going on
Best,
Muhammed
As a workaround you can get the same ACES sRGB look by using the filmic tonemap layer until this is fixed
You can get a similar look, I explain the workflow for this here
Funny thing is as in 5.2 the sRGB was not working and I was using sRGB D60 - now in 5.2.1 it is the other way around.
edit: it was 5.2.1 and 5.2.2 actually.
and again. back to sRGB D60. switching for a second to another ocio config file helps every now and then but I would at least expect some basic level of consistency from a bug.
Thanks for the feedback as well :slight_smile:
Just leaving a note here for the Phoenix smoke and the Raytraced GI using V-Ray GPU if in the future anyone goes over this thread.
Currently the scattering bounces for the GI are limited internally when using V-Ray GPU. It is in the to do list to improve that and make it behave more like what you get with the CPU renders.
ok - I have the OCIO config loaded via environment variables for few days now and so far no issues. even if I load the file manually.
This is solved now in the latest nightly builds, it will be ported to stable soon.
Best,
Muhammed
good news.
I obviously jinxed it as it misbehaves again..
