my current project. there are much more pics of it, maybe i will post them later. this was the project i needed the technical cam script. mabye now you can imagine why. my provider is offline at the moment so i have to post it this way. i hope it will work.
FOR SOME REASON THE COLOURS AND THE RESOLUTION OF THE LAST PICTURE LOOKS TERRIBLE ! ACCTUALLY IT LOOKS NORMAL !
i will fix it later and post the real version. don´t want to cut it out of the html now.
Really, really beautiful! Congrats!
The only thing I’d point (if there was any) would be the size of the shadows casted by the trees. IMHO, it looks like you have one lamp behing the camera and the trees are very close to it, so it makes the leaves cast gigantic shadows. But maybe that’s just me.
Once again, great images!
Rick
Impressive renders. I just tried rendering an image @ 15000x11000. Unfortunately my computer wouldn’t accept it. Had to reduce it down to 10000x7000. It took 18 hours to render. How long did yours take?
Artistically I think your images create a fantastic mood. I can really feel the Sun’s warmth bouncing off the facade. The camera correction works well for the shot.
How high was your direct light set to? What was your multiplier for the env. light and did you use HSV for colour mapping?
i split up the picture in f.e. four pieces and render each piece with it´s own irrandiance map on four machines. so each machines “just” have to handle a resolution of 3000 x xyz. in photoshop you can put the pieces together. vray is so clean you can´t see anything, although each machines calculates it´s own map. works perfectly !!
for the picture i have used the normal linear colour mapping. the multiplier for the direct was 1.8 with a darker orange. the env. was 1.35 with a “middle” blue
now i´m rendering the backyard again. displacement is great, but in that resolution it takes a lifetime to render
im still drooling excelent work .. absoutly excellent… mind posting your lighting settings ? and maybe u may explain more about how u did that wonderful grass???
for the front i have already posted the settings. the backyard has nearly the same settings. i normaly use a multiplier of 0.75 for the first AND the secondary bounces. envr. light a middle blue with 1.3 and a direct with 1.4.
for the direct a normaly use a brighter blue, not yellow.
