"Everything has fresnel!"
I was just curious on peoples workflow when it comes to using fresnel reflections. I was wondering if you guys always turn on"Use Fresnel" for reflections whether your making just rubber shader where you mainly see just highlights to a chrome shader or does it just fall back on the “what ever looks good” approach.
Michael
Well, for me, everything looks better when I turn Fresnel on everything. I’m sure someone could argue both sides.[quote=“michae, username:michae”]
Michael
[/quote]
I use the falloff map in max to push the fresnel effect for drama so you get a very obvious gradient between reflective and not, mainly for style reasons though. If you’ve a good environment things tend to default towards very realistic which is a nice place to start. Metals don’t use the fresnel curve, they use a way more complex curve which is almost flat from front until you get to the edge, then there’s a slight dip before it shoots up to 100% reflective. It’s also a slightly different curve for the red, green and blue portions of the material so most people settle on using a fresnel with a really high ior (25 upwards) or just use a flat colour for the reflection strength and no fresnel at all. Here’s a reflectance curve for three different materials from wikipedia - would be hard enough to get with a fresnel curve!
would be cool to have ability to load those curves as fresnel.
You can load them in a Ramp or Gradient map to use as reflection strength.
That’s one thing that max lacks - maxscript access to the output curve which could give you a sneaky way to do it. Must look into mapping gradient ramps to falloffs for this. Vlado is that type of curve data readily available for a lot of metals? It’s not something I’d have thought about before but it’d make sense if there was a handy table of data like an ior table with numerical data that could be changed into luminance values for a ramp?
Interesting point. So do you think that RGB reflection could possible have slightly different IOR per R,G,B rays or its that same across all channels?
I’ve seen data for some metals where it definitely does - It’s possibly more complex than just rgb but yeah there’s a tiny bit of variation in the three colours across the surface which gives you slight chroma splitting effects.
Humh interesting. So Vlado/Chaos is there a way to plug a separate IOR map in to each of RGB channels for reflections - asking because stuff like that will affect very dramatically flakes/car paints accuracy/realism.
Thanks, bye.
If you go the ramp/gradient route, then there is no need to - you have full control over the reflectivity for red/green/blue (or you can use a separate falloff map for each channel). I don’t think the actual physics is as simple as separate IOR for red/green/blue though.
Hi Vlado,
when you say the ramp/gradient way. is it just a matter of plugin a ramp in the reflection colour?
Thanks.
I’m wondering if there’s a bit of confusion in this thread.
If you notice - it’s alum, silver and gold on the graph - not RGB…
Yep sorry andy you’re right - they aren’t an RGB graph for a single metal, I didn’t make that clear, it’s a single curve for each material as you say. I’ve seen a few of those graphs though where for a single material they separate the RGB curves though, sorry for any confusion caused.
Yes; either in the color or in the Amount.
but a ramp plug in the colour would follow the UV of the geometry…
Use facing ratio.
Can’t you map a ramp to a sampler node in maya?
That what i usually do. I was hoping for something more physically correct.
If you recreate the measured curve, it will be perfectly physically correct…
I am wondering how you would match the curve using the ramp node in Maya? It’s a bit tricky to visualize the gray scale ramp color as a curve…As least if we can have a curve with inserting control points to manually adjust the curve to match the calculated fresnel curve of a general wavelength…
