Evironment override map
Status: declined
Currently if we need to put a background map into the render we need to use 3ds Max Environment and Effects, I think this is a little confusing, could we have a dedicated slot into the Environment tab in V-Ray Tab? similar to Corona Scene environment? this way, we have everything in the same place
Submitted on AHA Ideas (VRAYMAX-I-84).
Hi, as you mentioned there is already a way to apply a map.
You could also apply a Background layer in VFB if you have an image with a certain composition that you need to match.
Submitted on AHA Ideas.
I totally forgot about Background Layer in VFB, that really works phenomenal, but theres something missing, I think I already submit a different idea asking for a way to control Scale for this layer, Stretch-Fit-Fill are not optimal, an offset for Horizontal and Vertical scale will work better, hope you can work on that.
Yes, the idea is up for voting. Let’s see how it goes.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
