Hello brandpartners,
Thank you for your patience.
We reproduced this issue in our environment.
Thank you for pointing this out, we will clarify the reason.
We could proffer you this workaround - I will explain it step by step.
- Export a .vrscene from SketchUp with your original resolution 70866x35433
- Open V-Ray Standalone
2.1. If you haven’t used it before, you can find it in C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayappsdk\bin
Here is virtually explained.
3. Split the image into parts using the crop command in V-Ray Standalone
-crop=x0;y0;x1;y1- set the crop region to render.
The integer values are in pixels, relative to the upper-left corner and lower-right of the image.
To stitch 2 separately rendered parts (if you have enough RAM), when you open V-Ray Standalone write:
vray.exe -rtengine=5 -scenefile=/path/to/exported/file.vrscene -crop=0;0;35433;35433
Press Enter and render Part 1.
vray.exe -rtengine=5 -scenefile=/path/to/exported/file.vrscene -crop=35433;0;70866;35433
Press Enter and render Part 2.
If you don’t have enough RAM, you can split the image to more than two crop-regions. For example:
-rtengine=5 stands for GPU/CUDA rendering, because in your previous post you mentioned that you’re using GPU rendering engine.
If you would like to use the CPU device for rendering omit “-rtengine=5” attribute from the command.
4. Combine the parts in Post-production
If you have further questions, don’t hesitate to contact us.
Tsvetomira
