Hi!
I already had two times the same issue with the same scene i want to render.
Render stops and V-Ray says: Exception in CORE: Internal error. Please save and restart as soon as possible!
I did…same issue again.
I would need some support to finish the scene.
My PC Specs:
Threadripper 1920X 12-Core
32GB DDR4
NVIDIA GeForce GTX 1070Ti
Render Engine: CPU only
Thanks a lot already in advance for your help!
Hello @LionHeart1985 ,
Could you please open your Progress Log (icon is found at bottom right corner of the V-Ray Frame Buffer) and check for any error messages.
Additionally, please follow up on the private message I have sent you.
Hi @Zahari.Ivanov
I was just testing to render the same scene with a lower resolution.
With 1920x1440 it worked, but with a higher resolution (tried it 2 times with 3840x2880) it seems that there might be a problem.
Also the Log looks not as it should.
It´s way too long that it fits into this post but a lot of
Invalid geometric normal (0 0 0) for “<unknown>”.
Invalid geometric normal (-0 -0 0) for “<unknown>”.
are showing up and i don´t know where this is coming from.
As i just received a message that his is also happening to other people, after a few tests, here is my solution on this.
My model was shifted in -Z Axis.
I was moving the whole model with the lowest point on Z=0 and the problem was solved, i could render the scene without any issue.
Same problem in V-ray for Sketchup, I move the axes position and it works! thank you!
Hello @marco_mascher
Thank you for your post and welcome to the Chaos Forums!
It is good to know that this solution worked for your as well. If you happen to experience any other difficulties or issues, the Chaos Support is at your disposal.
Best regards!
Same here,
I have been facing this issue for like two days now.
Have tried reinstalling the license server and vray.
Axes positions are right, been working only on a simple moodboard with low resolution.
It would be great if someone help me
out on this issue, thanks in advance!
Hello @isssyyy_i ,
I would like to ask you to share your scene, so that we can identify what is causing the issue. You can do this by packing your scene (Extensions > V-Ray > Pack Project) and attaching the archive via a support request. Please make sure to mention this forum thread in your support request!
Thank you in advance!
Kind regards,
Iva
