When I use the hair and fur modifier and try to set the “segments” parameter above 26 then vray throughs an exception when trying to render. Also, the “mr prim” option in the effects settings for hair and fur does not work with vray as it says in the manual. Only the “geometry” option seems to work…
Yep, that’s a 3ds Max problem, unfortunately - there’s nothing I can do about it on our side. So your only option would be to get the mr prim working. Do you have problems rendering the hair&fur in other scenes? Can you post a scene which doesn’t work for you (or send it to vray@chaosgroup.com)?
