Excessive glow in rendering, with 2.0 version
I try the new version of enscape. An is incredible the grass, the ligthing effect have excessive glow. In my wall i can’t look the shadow in the vertex.
and my options values is exactly iqual in the before version.
Are you sure that Auto Exposure is enabled? That should usually prevent such overbright results.
Yes, autoexposure is enabled.
Look at this. all dark with autoexposure enabled.
Hi @jokebume
Picture 2: Looks better than your first picture. If it’s still too bright for you, you can reduce the percentage of the auto exposure.
Picture 3: In the top right corner is a very bright spot, looks like a window, which results in a dark overall picture. In such cases you can add other bright light sources or more windows. Also you could disable auto exposure and brighten up the room manually by increasing the Exposure Brightness.
If the Auto-Exposure is disabled, the exposure brightness has a bigger impact.
You can share your project with us for further analysis if it’s not working out.
Yes. But i present my project in walkthrough so i can´t adjust the exposure all time. The version 1.0 is better in this aspect, but the minimap and grass looks great!
Yeah, that’s why I recommended to insert more windows, add light sources or to remove the one window in order to prevent to get that dark result.
Its like walking in a room with a small very bright window which is blinding you, everything would be dark in this situation.
You would cover the bright spot with your hands in order to see more in the room but your eyes would need time to adjust the brightness.
In this case the ambient occlusion darkens such situations.
As a first step I would recommend you to set ambient occlusion to 0% or in order to avoid such situation completely to use Low quality settings as the light is processed different this way.
Hey,
I’ve been experiencing similar exposure difficulties in 2.0. I understand that when you walk into a room with a very bright light outside, it will make the inside darker, but it would be great if there was a box to check so there was a baseline that the exposure wouldn’t go below. Before 2.0, the ambient lighting was very good for showing the architecture and overall space, but with the update it is very difficult unless you have a fully developed lighting strategy modeled.
Reducing the ambient occlusion to 0% helps make the darks not AS dark, but as you can see below, its still basically black. So far I haven’t been able to effectively reduce the overall brightness of the exterior to mitigate the contrast.
Can you think of any setting arrangement that could help? Since we do client walkthroughs, we will likely go back to 1.9 to avoid blackouts like below.
@Woody_Bergman for the old lightning you would have to set the rendering quality to “Medium”/“low”.
Good to know!
Do you think a future update will have something to set a baseline brightness when auto exposure is on? The exposure work very nice for spaces that have developed lighting, but it would be nice to get high quality rendering walkthroughs with the ambient lighting of 1.9.
@Woody_Bergman a baseline brightness would be hard to handle. Lowering the quality to medium or low should manage it already.
