Exchange Materials
Swapping material still doesn’t work in Vantage 1.7 for Cinema I thought version 1.7 fixed the problem?
You can exchange the materials individually, but if you want to select all and exchange one material completely for several objects, it doesn’t work where is the problem with Vantage or Cinema 4D ? would be great if they could fix the problem need it for customer Presentations!
Hi Mr. Pock,
Can you send a simple sample scene or us to examine?
Alexander
Here is the sample scene
Chaos Testc4d.rar (1.5 MB)
I also noticed that the object hierarchy in the example scene does not work properly when hiding all objects, only one object is hidden, etc.
Hi Mr. Pock,
The issue with the applying materials to several objects is that in the vrscene there is an individual material for each object instead of 1. This messes the logic when imported in Vantage and each object is treated as having an individual material. We will look into it and see if it can be improved.
Regarding the other issue with the hierarchy, this is happening because the objects have same names. We have a logged issue for such a case where it causes issues and we will investigate it in the future. However there is a workaround for this - make every object have a unique name.
Alexander
Dankeschön
One question, why can’t you just exchange the materials with each other in Vantage, then I don’t care about the objects and the transfer from C4D?
You can change/reassign the materials in Vantage if the objects have unique names. If you reassign all objects with 1 material then the alt+drag a new material will work for all objects.
Alexander
