exclude from reflection -> black color
in vray next the exclude from reflection option is broken… https://c2n.me/3USxxM7.png
it doesn’t exclude the reflected object, it makes it black but still visible
the image should look like this https://c2n.me/3USxIYV.png
is this a known problem?
best regards
themaxxer
wow, I have made some tests, and if this is a problem with vray next, then this is really bad for me, because I use the option to exclude something from reflections all the time…
it seems you cannot exclude anything from reflections.
Yep, did a quick test and it happens here too. Looks very similar to this problem I reported just a couple of days ago.
Can you send me a simple scene?
They look very similar indeed. The workaround until it’s fixed is to use Trace sets.
