Exclude lights from refl
Hi all.
dond’t really know if its maybe a wish for max.
but would find it really helpfull, if you could exclude objects also from reflection/refraction in the exclude option in Vraylights.
i have a scene, where i want the light to emitt specular, exept for one object.
so maybe its possible?
best regards
Jonas
I’m a bit late but I second this!
Yes good idea…
Fourth that!
hmmm doesnt emit specular checkmark do that already?
not really, in this case you can exlude reflections/refractions per object.
btw, started this wish 3 month ago. nice delay :slight_smile:
Morbid Angel - it does it for the whole scene which isn’t helpfull in some situations - would be very nice if this was available on a per-object basis.
jonnybefree - :sweat_smile: better late than never…
But isn’t reflection/refraction more of a material property then a light property? It seems to me this checkbox should appear in the material editor and there should be a little “exclude” button near the reflection/refraction parameters of the material.
Could be done both ways I suppose. Just so long as you can isolate one object (or matl) in the scene.
actually such thing is possible in mr, each mr shader has a light link built into it. And since in mr each of the layers such as diffuse spec and reflection is its own shader they can all be separated on per light basis. It gets complex though.
I’d post the same problem… :cry:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17021&highlight=fabe
Thanks Fabe, I must have overlooked your post.
Looks like we’re going to have to do it the hard way then. :frowning:
