Hey guys,
Since Corona can’t render motion blur on deforming objects, is it possible to generate motion blur for the other objects ignoring those deforming ones?
Thx,
Alvaro
Hey guys,
Thx,
Alvaro
This should work on deforming objects, if you disable Multithreaded parsing (with Multithreaded on, and geometry motion blur enabled, Max will freeze - also if you add a Velocity render element too)
Using Skin or Skin wrap modifiers may lead to crashes in certain circumstances - for example when using motion blur.
Solution: disable “Multithreaded parsing” in Render Setup > Performance > Development/Experimental stuff
Let me know if that gets the motion blur working in your scene!
the skin crash bug was fixed already in 1.4 AFAIK
