Hello.
I am trying to use a vray dome as a direct visibility/reflection element, that is a 360 panorama and is linked to a sky rotation. But colors start to shift a lot when doing basic color corrections on vfb or reducing burn ammount on color mapping.
Is there a way to exclude some elements from color correcting? Or something to think about?
Hi so you are using the dome light with hdri as a visible sky? You could use masks in the VFB. Please give us a bit more details about your workflow best with images/screengrabs.
Hello
I started using cryptomatte to mask that. It was not my first option, but it works they way i´ve imagined.
The only issue is that refraction needs affect all channels switched on. But that´s fine for what i am using.
