Exit Color
I just notice that in the new Vray Next the Exit Color option isn’t present. Where was it moved as I can’t find it? In the older versions, it used to be located next to the Fog option. The Vray Docs still states it as an option. Thanks in advance. Cheers
Hello!
In V-Ray Next refraction exit color is no longer visible in the UI. We will update our documentation. Thanks!
Thank you for the reply - if it’s no longer visible in the UI doesn’t this mean the option as been removed from Vray all together? Or is it found elsewhere? Is there a work around?
cheers!
Hello! I meant that Exit color was removed in V-Ray Next. You might find helpful reading this thread :Exit color - General - Chaos Forum
gone? just saw a video about Clarisse 4.0 were one can use an HDR to map it into the refl/refr exit color, really nice because one don’t need extra high ray depths
