Hello there,
I am trying to make an expanded metal material with archicad + enscape and I could use a little help.
The material will represent the outer skin of a composite material.
How do I avoid having a backside of the material?
I would like to have a simple colour to control the diffuse and an alpha map for the actual shape of the metal.
Thank you.
Has anyone found an easier way to create an expanded metal part without it being 20-100mb part? I’ve been on grabcad, 3dcentral, google, and havent read or seen a part worth using that doesn’t bog down my computer or crash solidworks. Using Solidworks 2019 if that matters.
kabosu coin
Try using this as a displacement map
https://farm2.static.flickr.com/1299/4665675989_51a01679a7_o.png
You’ll need to make a transparency map to cut out the holes, but that should be a 30 second minute job in an image editor
