I noticed there is a section on the render lop “vray>output>experimental” that seems to suggest we can render to the VFB in Solaris. Is this something that is functional by default, or do I need to set anything extra to get it to work? When I click “Show VFB” nothing happens, with no errors or output in the console. Just curious, as using the VFB to view and inspect local renders would be amazing.
On Windows using H19.5.435 and V-Ray Core 6.00.21 from 9 Feb 2023
When I click on “Show VFB” nothing happen, even if I started viewport render, the same for hus, when i click Render to Disk, VFB not appear. Houdini 20.5.613. Vray 7, latest nightbuild
@Mikhalenko
Try to enable “Settings Dir” (1.) and “History Dir” (1.) - and choose “rendersettings” (2.)
Sometimes its also recommended to click “Reset Vray” under point 2 in my screenshot
