Hello
So we have this lovely command vred(camera=“persp”) and I can set filename-prefix to c:/some/fancy/path/filename
and then he will render into that filename, but he will then add _tmp.suffix…
How can I ask vray to NOT add tmp ?
I just want to render explicitly to a specific location as I want to be in full control of the output location for my images.
Any way to do it via python?
Regards
Dariusz
Maybe this thread will clarify things. I need to ask around if this can be worked around with Python.
Hey
Yeah, I’ve seen that topic.
Sadly it’s not something that is… “good” I was hoping 4y later there might be a solution…
It would be amazing if
import maya.cmds as cmds
cmds.vrend(outputPath=“C:/somefancypath/path/”,ignoreTMPSuffix=True)
Or something like that.
I know “Maya has its way of doing things” but we all think it’s a “stupid way of doing things” and we just want to “save render to this path with this name”…
Any way to do it via c++? I’m writing a plugin for maya, so if we can change that thing via C++ that’s also an option.
We just want to save the file to where we want with the name we want. Not maya/output/tmp(WHY?)/filename.exe or maya/output/myFancyPath/filename_tmp.exe
I’ve just had a dig at deadline to see how they are solving it, but sadly they use MayaBatch which I guess… does things differently as using the same command did not work in maya GUI
Any help would be great.
Regards
Dariusz
It seems rendering with Maya Batch does not create the tmp folder or _tmp suffix. I need to ask the devs if you can use the vrend function for Maya batch as a workaround.
What command did u use for render batch, ```mayaBatchRenderProcedure(0, “”, “”, “vray”, “”)``` ?
For now my “current” workflow is to just do
vraysettings.filenameprefix c:/some/fancy/path/somefilename.exe
and when he renders I get somefilename_tmp.exe
so the current idea is that after render ends loop over files and regexp find the _tmp suffix for the filename I give it and try to rename/remove it manually. But I don’t like it one bit ;////
Vray batch “could work” if it can show frame buffer in GUI so user can see the progress… but I think batch starts new scene and it takes forever on big scenes so no1 will want to use it
Thanks for looking in to it!
Update: we added a new flag called “-skipTmpOutputSuffix” in the latest nightly builds. It ignores the “_tmp” suffix for files and the creation of a “tmp” folder if using the project output defaults. We’ll pick it up for the next stable build.
AWh that’s amazing, thank you so much!!!
