Export exe error
Enscape version 2.0.2.1844, win10, SketchUp 2017.###
Fixed in 2.0.2.1920
Nope still doesn’t work in Revit!
That same error with Enscape-Dependency-Setup.exe inside or another one? Please send feedback.
This is what we are seeing.
Are you sure you’re using the 2.0.2.1920 version? Please use the feedback button. Need to see your logs.
Well…I have downloaded the 2.0.2.1920 version however when I check the About tab it still says the previous version even though I’ve done a fresh uninstall and reinstall?
Don’t worry…sorted it! My ‘local’ version was still set to the previous version for some reason even though I selected to install across the entire machine.
So, the bug is really fixed in 2.0.2.1920 - your problem is you use the older version.
Did you install the 1844 version for all users and the 1920 version for current user only? You might want to run the uninstall.exe in your installation folder(s).
Another reason for the wrong installation might be, that you had your CAD software open when you installed the new version. This prevents the installer from running correctly, because the files can’t be overwritten.
