Export Group of objects into CORONA PROXY with maxscript
Hi
is there a way to export a group of objects (a group not a selection) with maxscript using:
CProxy.ProxyFp.fromScene (CProxy()) “groupnode” @“D:\myproxy1111111.cgeo”
much appreciated
this will work for you.
CORONA TEAM PROXY EXPORTER
DESCRIPTION:
    Converts selected geometry or groups into Corona Proxy (.cgeo) files.
    Works with single objects, multiple objects, and grouped objects.
    Automatically handles closed groups by opening them temporarily.
HOW TO USE:
    1. SAVE YOUR FILE FIRST! This script modifies your scene.
    2. Select the object(s) or group you want to convert to proxy
    3. Run this script (drag into viewport or run from MAXScript menu)
    4. Click "..." to choose where to save the .cgeo file
    5. Set options:
       - Delete original: Removes source geometry after export
       - Collapse to single proxy: Combines all selected into one proxy
       - Keep in group: Places new proxy inside the original group
    6. Click "Export to Proxy"
OPTIONS:
    - Delete original: Check to remove the original objects after proxy creation
    - Collapse to single proxy: Merges all geometry into one proxy file
    - Keep in group: If source was in a group, proxy stays in that group
FEATURES:
    - Auto-refreshes when selection changes
    - Works with nested groups
    - Preserves object positions
    - Names proxy as "originalname_proxy"
REQUIREMENTS:
    - Corona installed
    - 3ds Max 2020 or newer recommended
    global CoronaTeamProxyRollout
    try(destroyDialog CoronaTeamProxyRollout) catch()
    rollout CoronaTeamProxyRollout "Corona Team Proxy Exporter" width:480 height:260
        dotNetControl lbl_warning "System.Windows.Forms.Label" pos:[10,8] width:460 height:22
        label lbl_info "Select object(s) or group, then choose export path:" pos:[10,35] width:460
        edittext edt_path "Path:" text:"" pos:[10,55] width:380 height:20
        button btn_browse "..." pos:[400,55] width:40 height:20
        checkbox chk_deleteOriginal "Delete original" pos:[10,85] checked:false width:150
        checkbox chk_collapseGroup "Collapse to single proxy" pos:[10,105] checked:true width:180
        checkbox chk_keepInGroup "Keep in group" pos:[240,85] checked:true width:150
        label lbl_selected "Selected: (none)" pos:[10,140] width:300
        label lbl_geoCount "Geometry: 0" pos:[10,160] width:300
        button btn_refresh "Refresh" pos:[380,150] width:70 height:22
        button btn_export "Export to Proxy" pos:[10,195] width:180 height:40
        button btn_cancel "Cancel" pos:[200,195] width:100 height:40
        local selectedNodes = #()
        local collectedGeo = #()
        local parentGroup = undefined
        local openedGroups = #()
        fn openParentGroups obj =
            local p = obj.parent
            while p != undefined do
                if isGroupHead p and not (isOpenGroupHead p) do
                    appendIfUnique openedGroups p
                    setGroupOpen p true
                p = p.parent
        fn restoreGroups =
            for grp in openedGroups do
                try ( setGroupOpen grp false ) catch ()
            openedGroups = #()
        fn getGroupChildren groupNode =
            local children = #()
            local wasOpen = isOpenGroupHead groupNode
            if not wasOpen do
                setGroupOpen groupNode true
                appendIfUnique openedGroups groupNode
            for obj in groupNode.children do
                if isGroupHead obj then
                    join children (getGroupChildren obj)
                else if superClassOf obj == GeometryClass then
                    append children obj
            children
        fn collectGeometry sourceNodes =
            local geoNodes = #()
            local processedObjects = #{}
            for obj in sourceNodes do
                    if parentGroup == undefined do parentGroup = obj
                    local children = getGroupChildren obj
                    for child in children do
                        local idx = child.inode.handle
                        if not processedObjects[idx] do
                            append geoNodes child
                            processedObjects[idx] = true
                    local idx = obj.inode.handle
                        append geoNodes obj
                        if parentGroup == undefined and isGroupMember obj do
                                if isGroupHead p do (parentGroup = p; exit)
                                p = p.parent
            geoNodes
        fn updateSelectionLabel =
            selectedNodes = selection as array
            collectedGeo = collectGeometry selectedNodes
            if selectedNodes.count == 0 then
                lbl_selected.text = "Selected: (none)"
            else if selectedNodes.count == 1 then
                lbl_selected.text = "Selected: " + selectedNodes[1].name
            else
                lbl_selected.text = "Selected: " + (selectedNodes.count as string) + " objects"
            lbl_geoCount.text = "Geometry: " + (collectedGeo.count as string)
            if parentGroup != undefined do
                lbl_geoCount.text += " (group: " + parentGroup.name + ")"
        fn validatePath filePath =
            if filePath == "" do return false
            local dirPath = getFilenamePath filePath
            if dirPath != "" and not doesFileExist dirPath do
                try (makeDir dirPath all:true) catch (return false)
            if dirPath == "" do dirPath = "C:\\"
            return doesFileExist dirPath
        fn createCombinedMesh geoNodes =
            local combinedMesh = mesh vertices:#() faces:#()
            combinedMesh.name = "temp_proxy_mesh"
            for obj in geoNodes do openParentGroups obj
                local tempCopy = snapshot obj
                if classOf tempCopy != Editable_Mesh do convertToMesh tempCopy
                if (getNumVerts combinedMesh) == 0 then
                    delete combinedMesh
                    combinedMesh = tempCopy
                else
                    attach combinedMesh tempCopy
            ResetXForm combinedMesh
            convertToMesh combinedMesh
            combinedMesh
        fn exportToProxy filePath deleteOrig collapseToOne keepInGroup =
            if collectedGeo.count == 0 do
                messageBox "No geometry found!" title:"Error"
                return false
            if not validatePath filePath do
                messageBox ("Invalid path:\n" + filePath) title:"Path Error"
                return false
            openedGroups = #()
            local createdProxies = #()
            local origName = ""
            if collectedGeo.count == 1 then
                origName = collectedGeo[1].name
            else if parentGroup != undefined then
                origName = parentGroup.name
            else
            if collapseToOne or collectedGeo.count == 1 then
                local tempMesh = createCombinedMesh collectedGeo
                local newProxy = CProxy()
                local result = CProxy.ProxyFp.fromScene newProxy tempMesh filePath
                newProxy.name = origName + "_proxy"
                delete tempMesh
                if result == 0 then
                    append createdProxies newProxy
                else
                    delete newProxy
                    messageBox ("Export failed! Code: " + (result as string)) title:"Error"
                    return false
            else
                local basePath = getFilenamePath filePath
                local baseName = getFilenameFile filePath
                for i = 1 to collectedGeo.count do
                    local obj = collectedGeo[i]
                    local objPath = basePath + baseName + "_" + obj.name + ".cgeo"
                    local tempMesh = snapshot obj
                    convertToMesh tempMesh
                    ResetXForm tempMesh
                    local result = CProxy.ProxyFp.fromScene newProxy tempMesh objPath
                    newProxy.name = obj.name + "_proxy"
                    delete tempMesh
                    if result == 0 then
                    else
                        delete newProxy
            if keepInGroup and parentGroup != undefined and createdProxies.count > 0 do
                setGroupOpen parentGroup true
                for prx in createdProxies do attachNodesToGroup prx parentGroup
                setGroupOpen parentGroup false
            if deleteOrig and createdProxies.count > 0 do
                if parentGroup != undefined do setGroupOpen parentGroup true
                for obj in collectedGeo do delete obj
            restoreGroups()
            messageBox ("Created " + (createdProxies.count as string) + " proxy(s)!\nPath: " + filePath) title:"Success"
            return true
        on CoronaTeamProxyRollout open do
            lbl_warning.text = "WARNING: Save file before running! Use at own risk."
            lbl_warning.font = dotNetObject "System.Drawing.Font" "Microsoft Sans Serif" 10 ((dotNetClass "System.Drawing.FontStyle").Bold)
            lbl_warning.foreColor = (dotNetClass "System.Drawing.Color").fromARGB 255 100 100
            local defaultPath = maxFilePath
            if defaultPath == "" do defaultPath = (getDir #temp) + "\\"
            edt_path.text = defaultPath + "proxy.cgeo"
            updateSelectionLabel()
            callbacks.addScript #selectionSetChanged "try(CoronaTeamProxyRollout.updateSelectionLabel())catch()" id:#CoronaTeamProxyCallback
        on CoronaTeamProxyRollout close do
            callbacks.removeScripts id:#CoronaTeamProxyCallback
        on btn_browse pressed do
            local initDir = getFilenamePath edt_path.text
            if initDir == "" or not doesFileExist initDir do initDir = maxFilePath
            if initDir == "" do initDir = getDir #temp
            local savePath = getSaveFileName caption:"Save Corona Proxy" filename:(initDir + "proxy.cgeo") types:"Corona Proxy (*.cgeo)|*.cgeo"
            if savePath != undefined do edt_path.text = savePath
        on btn_refresh pressed do updateSelectionLabel()
        on btn_export pressed do
            if collectedGeo.count > 0 then
                local filePath = edt_path.text
                if filePath != "" then
                    exportToProxy filePath chk_deleteOriginal.checked chk_collapseGroup.checked chk_keepInGroup.checked
                else
                    messageBox "Please specify a file path!" title:"Error"
            else
                messageBox "Please select geometry first!" title:"Error"
        on btn_cancel pressed do destroyDialog CoronaTeamProxyRollout
    createDialog CoronaTeamProxyRollout
