I am using the latest Enscape and the new Render exporting. In the past, if Synchronize Views is turned on and my export aspect is set to match screen, the view would export and match SketchUps view. This latest version seems to ignore the Synch View. Am I missing something?
Hello @Matthew_Valero and thank you for the report! This is indeed a regression that we have confirmed in 4.19 and we have scheduled for investigation.
Ok, thank you. I’m glad I wasn’t missing something.
Could you provide an estimate on the fix for this situation? By the way, also you cannot control the file naming. This is not a regression; it is a significant problem for Enscape users. I have a work deadline in a couple of hours. I cannot use Enscape 4.19 . How can I download the older version?
@dario_dimauro Yes the filename issue has also been confirmed and is most likely getting fixed in the next version. You can access the Enscape download page and click on the “View older versions” link to access the list with all the previous versions.
