Export PhoenixFD to Houdini (VDB?)
Sorry to bother, just wantet to know if it is possible to get some sort of eta on this? Are we talking days or months? (I have no idea how complex this is!)
Hey,
Do you need it for 3ds Max or for Maya? We could either try to put it in the Mayan release, or we could add it to 3ds Max and make only the 3ds Max nightlies public again.
Cheers!
In max would be great, but if you do if as batch conversion script from .aur to .vdb, everybody could use it. :slight_smile:
We would be using it in Maya in order to assist with cloud rendering that doesn’t support phoenix, but has innate VDB and V-Ray support. Speaking of Maya, the 3.0 release is coming soon, no? This week? Next month?
Sorry, can’t disclose release dates :slight_smile: We’re working on it.
Cheers!
Hey guys,
Just an update on this - using a 3.0 nightly for 3ds Max now you can replace in the output path of a Phoenix simulator the “aur” extension with “vdb” and it would export VDB caches. Note that this way you need to set an explicit path and can’t use the $(…) macros. For now this is just an experimental feature and we will add a better interface for it with time. Please do tell if you find any issues with it.
Cheers!
would like to test these with Redshift - I was on the nightlies previously but logging in to the account only shows the FD 2 Nightlies and Vray for Blender - do I need to be added?
Thanks,
Steve
Yep - Phoenix 3.0 has different licenses, and thus a different nightly location with separate permissions. You’ll have to drop an email to Support and request permissions for the new nightlies.
Cheers!
Thanks, will do!
Tried to write out VDB’s today, but it still writes AUR. I made a specific path writing “test.####.vdb” but when i simulate it writes: “test.####.vdb.aur”. What am I doing wrong? (Using 30501.)
Hey,
3.05.01 is the generic name for all nightlies. Could you please check the Build ID in the About dialogue?
Also, if this is the entire path, it will not work - Phoenix needs a full path, not just the filename.
Cheers!
Sorry, yes, there is a full path to a network drive.
The build ID is
1611177063
It should be enough to just type .vdb in stead of .aur, right?
Yup, this should be all - just make sure you have a full path like C:\something\cache####.vdb or \\drive\cache####.vdb.
Does it still export aur files?
Found the problem! If you use the browse function and type .vdb, it will automatically add .aur to the path. If you delete .aur in the path in the modifier panel afterwards, it does output the vdb’s!
So I guess you need to add .vdb to fileformats in the browse function?
Ah, yes - the browser autocompletes it indeed - you need to edit the name in the edit box. We would wrap this and make it much more pretty than this state it’s in right now, but I’m waiting for the time for some other changes to come that would make it much more different all at once.
