You have mentioned that you are going to to create a popup menu to setup the number for proxy’s faces, It could be useful to have a checkbox to save the original object to same location for the vrmesh file. Sometimes I couldn’t reload the original Component because I created it in the Main file and purged the skp file after I created the proxy.
-Also having a checkbox to save the component proxy and other checkbox to purge the file after export the proxy would be useful, since these are a frequent steps.
Hello, and thank you for your suggestion!
We cannot add any of this as part of the NeUI as we keep it host-app neutral. There is, however, a possibility to integrate part of your suggestion as a pop-up window upon proxy creation.
The dev team will discuss it next week.
Kind regards,
Peter
Great, thanks, that exactly what I meant, a pop-up window upon proxy creation.
I had posted a feature request to add an option to V-ray Tools menu to offload all textures in the scene, it would be useful if we could have this option as a checkbox in the Export proxy popup window to offload the proxy textures.
