Export settings from Vantage: Colour corrections/Tone Mapping etc
Is there a way to export these into the 3ds max vray frame buffer? Maybe a LUT?
I only see camera option using the max vantage toolbar button.
No, it is not possible currently. It’s only possible in the other direction - you can export a LUT in VFB and load it in Vantage.
Is this something for the future perhaps then?
I can’t render out my final image on a 24gb card in Vantage (with all the render elements etc), so I have to render out in V-ray Max GPU. Would be nice if I could transfer all of the CC (hable) to the V-ray max frame buffer to have some kind of parity.
Manually inputting same values works ok though. I’m surprised how well V-ray GPU matches Vantage render by the way. Vantage is really impressive. Props to you and the other devs.
