Export to VRAY Mesh and MultiMaterial
I’m going through VRAY 3.X Tutorials using Rhino 7 and VRAY NEXT. The Lesson 2 section on Proxy/Export.
When I Export the VRAY Proxy object to the VRMesh, I do not get the resulting VRAY Multi-Material that is supposed to appear in the Asset Editor as the tutorial tells you will happen. Am I doing something wrong, or is that a change in NEXT from VRAY 3.x?
Thanks,
Thomas
Hi @scrappydog1958
The MultiMaterial is a legacy workflow and in its place a more optimized one has been introduced. When a proxy is exported and replaced in scene, the materials used for each faceID are part of the vrmesh asset in the Geometries tab
For further information, please visit Chaos Docs
Most helpful!! thank you.
Thomas
