Export video not working
Hello
I am having trouble exporting a walkthrough I made with Enscape in Revit.
When I export the program seems to be exporting but no video comes out?
Do you have any clue what is missing ?
Can you post the XML file of the video path?
Here is the xml file.
This is happening in other project also with different xml files.
Enscape_VideoPatharc.xml (1.35 KB)
Somethings not right.
Can you remove / reapply the timestamp to Keyframe Order 5?
The overall timestamp from the Video editor timeline (above) shows 46 sec overall.
But the timestamp in your XML file showsKeyframe Order 5 at 79.63 sec.
Hello Phil,
I removed keyframe 5 and tried export with no luck, nothing is exported :confused:
Is the xml file I attached ok ?
Enscape_VideoPatharc.xml (836 Bytes)
Let’s test simple path. Two points. Does that work?
