I’ve got some rendered 16-bit floating point .exr images and I want to apply the same color corrections as in the VFB to them. I saved a .cube file from the Color Corrections panel of the VFB and loaded it in Photoshop. Unfortunately I don’t get the same result as the images in the VFB. It looks dark and clamped. The same happens if I load the LUT in the VFB. Am I doing something wrong? Please check the images below.
Are you saving the EXR WITH the adjustements in image1?
Save the cube, then switch OFF all adjustments and save the EXR, now load the cube. Is that what you are doing?
Would it be possible to send us the .vrimg file, the exported .cube file and save another global color correction file in .vccglb file format?
Looking forward to hearing from you.
