Exporting animated camera from 3dsmax to Vantage
We often work with big masterplans, so to avoid memory errors we don’t use live link.
We also run in to problems when exporting the scene as a single big vrscene with animated cameras included.
I would like to split the geometry and animated camera vrscene files - it’s an animated dummy linked to a camera.
My steps were to isolate the geometry and export selected as a vrscene file.
Dummy, camera and target also isolated and exported with animation tickbox activated.
Then I open the geometry vrscene and import the animated camera scene with cameras only checked.
Problem is I see no camera animation in Vantage?
Also, is it possible to import multiple animated cams from 3dsmax and how would you render them out in Vantage?
No worries, looks like it’s working now.
In Editor settings I had to change the original camera to the appropriate animated camera - now I can see the animation.
My next question:
How would you do a batch render for multiple animated cameras?
For stills you can just select the appropriate cam but for sequences I don’t see an option to select a specific cam?
In sequence mode we render whatever the animation timeline (in the animation editor) contains for the given frame range. You could add multiple cameras one after another in there if you want. You may need to add short pauses between them if there are temporal artifacts when the camera jumps.
Hi philip_nel,
Currently rendering an animated sequence from multiple camera views is not possible in a batch. I would suggest you vote for it in the Vantage Idea portal https://chaosvantage.ideas.aha.io/ideas/VANTAGE-I-70
Alexander
