Is there way to get the velocity at a specified grid index? I’m writing a script to export a velocity field to Unreal Engine 4.
edit: Changed to c++. Maxscript is slow as hell on a decent grid size. Does PHD have an API?
Got it. Sort of. A_getv always returns (0,0,0):
MacroScript PhoenixFDToVectorField
on execute do
local phd = $
if classof phd != FireSmokeSim then
print “Expected selection to be PhoenixFD Grid”
else
local cellSize = phd.cellsz
local xCount = phd.xc
local yCount = phd.yc
local zCount = phd.zc
local filePath = getSaveFileName caption:“Export Vector Field” types:“(VectorField(*.fga)|*.fga”
if filePath != undefined then
-- Size
local exportString = ((xCount as string) + “,” + (yCount as string) + “,” + (zCount as string) + “,” )
-- Bounds
exportString += ((phd.min.x as string) + “,” + (phd.min.y as string) + “,” + (phd.min.z as string) + “,” + (phd.max.x as string) + “,” + (phd.max.y as string) + “,” + (phd.max.z as string) + “,” )
-- Velocity
for x = 1 to xCount do
for y = 1 to yCount do
for z = 1 to zCount do
local cellVelocity = A_getV phd (point3 x y z)
exportString += ( (cellVelocity.x as string) + “,” + (cellVelocity.y as string) + “,” + (cellVelocity.z as string) + “,” )
(dotnetclass “System.IO.File”).WriteAllText filePath exportString
Hey, sure - there is the aurloader which provides access to aur, f3d and vdb caches, and also there is an API for accessing the Max or Maya Phoenix nodes at runtime.
Here are the docs on the loader: Chaos Docs
And you can find the SDK here: C:\Program Files\Chaos Group\Phoenix FD\3ds Max XXXX for x64\SDK
When using this MaxScript, do you have the velocity channel exported from the Output rollout to the cache? Also, make sure to upgrade to Phoenix 3.05 ![]()
Hope this helps!
Absolutely fantastic, you’ve thought of everything!
