Exporting Nparticles as proxy
is it possible to export nparticle as a vray proxy?
I keep getting the following error:
// Warning: No instances in the current selection can be converted into proxies ! //
I also tried to instance a some poly sphere with my nparticles and they create a proxy from the instanced sphere, but that did work either.
I tried to export the nparticle as an alembic file to import as a vray proxy but I can’t get it to work either.
I am using Maya 2014
[2014/Nov/5|11:07:16] V-Ray: V-Ray for Maya version 2.40.02 from May 14 2014, 16:40:13
[2014/Nov/5|11:07:16] V-Ray: V-Ray core version is 2.00.02
Any tips?
I have this large nparticle simulation that I need to instance in order to create this enormous scene.
Thanks,
Yannick
For the moment it will only work if you export to Alembic and then convert to .vrmesh - we don’t have the particle export code in Maya yet.
Hi Vlado.
Thank for the answer.
I tried to export my nparticles as alembic but I couldn’t have it to work.
Also how can I convert alembic file in a vrmesh file?
Thanks,
Yannick
You can use the ply2vrmesh tool to convert Alembic files to .vrmesh files.
Thanks.
Any tips about how to export nparticle as alembic?
Yannick
Have you tried using the Exocortex tool? I thought the native Maya Alembic exporter works too, but you said that it doesn’t - I’m not sure I can help here though.
no problem, thanks again.
Yannick
