We’ve equalized most of the functions of the Particle Shader between Max and Maya - the only options you should watch out for are the Liquid tint which is not in Maya yet and you would use for compositing, and the Count Multiplier in Maya can only reduce particles but cannot increase them yet. All the other options are there and you should just need to be careful about using the same scale - e.g. bubble sizes etc.
So if I used the particle count to increase the particle count, is there a way to export it? By PRT or Alembic will it take the multiplied count into account?
