expose aditional parameters as maps too.
To be able to use the new compound in a more powerfull way with vray we need the Additional parameters as maps so we can plug OSL float parameters for instance.
Otherwise compound will jus put them all insidide the compound and that is not practical.
Hi, thanks for posting. Could you give us an example of your workflow with other render engines and the new compound?
Could you elaborate a little more on this? It is not clear what workflow you are using.
