Please do so that “Exp.&col/mapping” could to affect to whole VFB
Now it affects only to the region area if I run rendering of the some area of the image and doesn’t affect to the whole other image area
i could to affect
seems it got fixed some time ago
Hi Ondra!
It’s bad but nope(
If was run render in region area then postproduction affect only to the region area
what build are you using? can you record a video? I just tried it again and it is working fine - Imgur: The magic of the Internet
26/12/2014
ok. I’ll write the video
ps: )). while I wrote the video I have saw it works in Corona VFB but it does not work in Max FVB
https://dl.dropboxusercontent.com/s/bhr0m1qrj154umw/Screencast%2002-00%2027-12-2014.mp4?dl=0
The fact that you are using native VFB was pretty important ;).
OK, I fixed it also for native VFB
Yep ^)
well I am using both of vfb - depends from case what the same of two vfb would be more usable.
Thanks Ondra!
