Exposure Value Cant be Clicked
Hi everybody ! im new to corona, and it seems like my exposure value cant be clicked when i hit render button even after image in done rendered.. what seems to be the problem here ? how can i fix this..
please ! i need your advice.. thank you
If you are using a physical camera in MAX then you need to disable exposure control for the camera in your environment settings.
I SEE. THANK YOU FOR THAT , SO IF I USE CORONACAM ? WOULD IT MEAN THE OTHER WAY ? DISABLE MAX EXPOSURE ?
Hi. First thing: Take off Caps Lock on your keyboard :smiley: Second: When using Corona, always disable Max exposure (you can use it, but it makes things a lot more complicated). Third: if you’re using the EV control override on physical-camera or Coronacam, then this will lock the exposure control in the VFB.
Hope it helps
