I am not sure what is causing this but, when I am rendering vantage is amping up the exposure.
Hi brad_zubrick,
Have you enabled Auto exposure in the Render setup dialog by accident?
Alexander
Thank you for the reply. If taken the time to read the title/description of the screenshots I uploaded, you would notice that I posted four screenshots. One, that is a screenshot of a paused rendering with auto exposure on, second is a screenshot of viewport with no rendering and third is a screenshot of rendering with auto exposure turned off. Fourth screenshot is all three together in that order. The exposure result you see in the paused renderings is the same when the renderings complete. There was a similar issue with an earlier version of vray and the difference between and ipr render and a final rendering that was a few years before vantage was released.
Hi brad_zubrick,
If auto exposure is not the case, then we would need the scene to investigate it as I cannot think of any other reason why the exposure wouldn’t match. You can use the Chaos Help form with a link to the forum thread:https://support.chaos.com/hc/en-us/requests/new You will have to include all asset files.
Alexander
