Anyone else running into the following? I saved out a screenshot with the default exr file type and when I open it in PS I get the attached. Not only does it look very strange, but it give me two images side by side. The png is what it should look like.
@vjaramillo_cg , I was not able to reproduce any problems with our generated .exr renderings - do you experience this with other .exr files which were not created through Enscape, I suspect not? Can you perhaps send over the .exr file as well which you’ve produced? And are you using our latest release?
It also definitely can’t hurt to upgrade your GPU drivers if you haven’t already, via either the NVIDIA or AMD homepage.
It should now be possible to upload .exr attachments as well - if the file is too large, please kindly use wetransfer.com for example to quickly upload the file there and kindly send me the download link. Thanks a lot again in advance!
