EXR render
Can you save a sequence image as EXR from vantage? How can be done?
Thank you
Hi frankc,
Yes, you can save out .EXR files from Vantage. You have to specify in the output path and .exr extension instead of the default .png one. Also the following render elements will be automatically exported when exr is specified: BumpBormals. Velocity, ZDepth, Background.
Alexander
Hi Alexander, Do I have to save the output path in vray 3dsmax or should I save the output path in vantage software? Thank you
Hi frankc,
You have to save the output path inside Vantage, not in 3ds Max.
Alexander
