EXR save element problem
VRayCryptomatte VRayMtlID VRayObjectID VRayDenoiser after saving the four elements in the EXR, the VRayDenoiser element in the AE does not exist. The VRayDenoiser element is not visible but cannot be used by the other two ID elements, and the VRayCryptomatte element also indicates no data?
Hi, what happens if you try to load the saved EXR in a clean VFB? On my setup all render elements are there and work. Could you share the EXR file that you have issues with?
Now the problem has been found. It seems to be a bug in Vray version 5.20.02. When I reduce the software to vray 5.20.01, everything is normal,
In the new version of vray 5.20.02, vraycryptomate vraymtlid vrayobjectid vraynoise and sRGB in display correction are temporarily found; Gamma 2.2; OCIO; ICC; The configuration information of cannot be saved to EXR format file
The specific screenshots and attachment information can’t be sent until one day. I wonder if my description can be clear
Hi I looked up your scene. You have color corrections layers in your VFB. That is why there is a difference between RGB and render elements. If you want to apply and save the color corrections to the render elements you have to use this:
Crypto matte works (V-Ray 5.20.02).
Hi, section 2 as you call it saves separate EXR files for each render element. You will have the VRayObjectID and the VRayMtlID as separate lifes and you can load them in After Effects.
