exterior glass
Am I doing something wrong here? In an exterior scene I cannot seem to get the glass to be very realistic…it lacks reflection. In following previous advice, here are my glass settings on a vray material:
reflect - 161,161,161 (rgb), frensel on, IOR 2.0, max depth 20
refract - 202,216,214 (rgb) IOR 1.3, max depth 20, affect shadows on. Previously when using standard materials and either raytrace or flat mirror reflects, I would normally have the background environment reflected…but here…nothing.
Any help would be greatly appreciated!!! Thanks.
http://hyperupload.com/download/fa5fed49/rainbow02.jpg.html
the ior is set too high, i think.
delink it and set it to something between .3 and .6
set the max depth in the globals to 10. this should be enough.
I usually don’t even bother using Fresnel reflections for exterior scenes… but when I do I use a Max Falloff map instead of the vray Fresnel option, as it gives a bit more control over the actual numerical values of the toward/away reflection variables… It may not be physically correct but it works well.
