exterior Hotel in process
c&c welcome
Hiya, nice image. The cobblestones/paving are ruining it though. The paving in the distance could do with a higher res map so it doesnt tile so much and the coloured cobbles in the foreground I would fix up in PS so the tiling isnt so obvious ie select one of the cobbles that doesnt stand out so much and cover it over the pinker ones which stick out. The brickwork to the left looks the wrong dimensions, as though its stretched sideways, this could be down to the uvw map which may need tweaking. Also, the man under the umbrella should be in shadow, maybe just darken his upper body a little and take some of the red out of his skin. Maybe some lunch/drink items on the tables to liven it up a little? Apart from that good job.
thanx, I will use your comments
greetingz
leon
