I would make the pool less ocean like (remove the large waves) and you can also animate the phase of the clouds slightly (if you are using CoronaSky map with clouds), and everything should look more lively.
Btw, how was your experience with caustics in this animation? I see they are close to perfect without any flicker. Did you use a special setup for this or you just rendered it out using simple bump over the pool? I am asking this mostly for other users who have had issue with caustics flickering. This is a good example on how caustics can come out without much hassle.
Thanks for your comments, when I did this project the Corona Sky with clouds was not available yet if I remember, so the background and windows reflections are a Still Jpeg, but I have used it in more recent works and it really is great for this kind of shots. Regarding the caustics, I’ve done a lot of RnD to test caustics to see what works, and this setup is a PhoenixFD Ocean Tex as a displacement map and on the UHD Cache I have the Animation preset but with the “Calculate from scratch” and After render “Discard”, Render Noise Level at 4% with the Denoising to help clear.
