Vray For SU. No bump, no displacement used for fast rendering. C&C are most welcome.
red car - no post processing except the background.
blue car
Re: EXTERIOR PERSPECTIVE USING VRAY FOR SU(red car + blue car)
will u be doin a slower render version!
this thing would be a cracker if u could add displacement to the roof tiles and the stone cladding!!! and give the car materials a some reflective properties! ![]()
the concrete pavement in the foreground in the second image doesn’t look rite… the first image’s is better!
oh and if possible add curtains inside those windows! ![]()
Yeah…Noted! Thanks for the C&C’s. The thing is, this is an actual project with deadlines involved. Anyway, I’ll try to add those if time permits.
Mike
Looks good but you need some better ground textures - these look like a chocolate dessert!
Have you got an image in the environment slot?
David
Yeah David, I better get some good ground textures. Thanks for noting that too. I don’t have an image in the environment slot. Why?
Mike
There are some good ground textures here (you might have to adjust them to suit)
If you put an image in the environment-background slot as an ‘environment’ you can get some good reflections off your windows which will help with the realism.
I think your roof tiles look ok - quite realistic at this angle.
Good Luck
David
Thanks David! Will look around and see what I can do.
Mike
mike this is already good for intial presentation. and i think the setup and model is good. perhaps you can add metal reflection(look at rhino help how they do the material for car metals--- double reflections), bumps, refelction on those lamps, more reflection on the glass, slight soft shadow, etc.. it may take a abit longer rendering but it will gonna be one of the best exterior render here.
David, I tried putting an image in the environment slot but it didn’t work out well. The sky turned all black and the glass turned off its reflective properties. Why is that so?
I attached the image and set it as environment, as well as texture but still negative. How can I put a better reflection on my glass? Do I have to put billboards in front? Put HDRI in the env settings?
Thanks in advance!
Mike
Salamat Nomer. I tried rendering another image and tried to put the reflections on the car, displaced the bricks, and put bumps on the floors, unfortunately, it didn’t work quite well. My pc froze because of lack of RAM. I only have 1gb of RAM and some system resources are eating it all up. I wish I could have additional RAM up my sleeve. ![]()
Mike
It sounds to me like the bitmap multiplier for the image you have use needs wanging-up. I set regular jpg’s to about 50000 like this (also note the other settings)
Billboards - I now only used these if the ‘environment’ background doesn’t give me the correct reflection. So then I position a billboard, where it will reflect in a particular window.
If I was you I would keep the car simple - just add a reflection layer to the material, after all, the image is not about the car but the building.
Good Luck
David
Thank you very much David. Will try your settings. I hope it turns out well. Regards!
Special thanks to Jenu, Nomer & David for their tips & suggestions!
Anybody here wanna comment on my revised exterior perspective? Need some inputs… Thanks!
I’m now working on the reflective layers & displacement issues. So far, i’ve incorporated them and cut the file by half.
Mike
Its looking good. As you say, softer shadows would be nice. Have you got a background with some blue sky - to match your sunny view?
I’m still not sure about those concrete textures, but everything else is fine.
Regards
David
Thanks David for the inputs. I used HDRI instead of a jpeg image in the env. I’ll have to look for a nicer background just like you said. With regards to the concrete texture, its the closest to the actual road site. The driveway finish is just what the client wants, plain brown toned concrete finish with tile borders.
Mike
mike!
nice job on the tiles and stone cladding! did u group those before u did the displacement??? that thing works now for me! ![]()
and nice touch on the curtains!
beautiful!
Thanks Jenu. You, Nomer and David gave me some valuable tips. Yes, I grouped them and add displacement.
I’ll probabaly post the backyard view tom or day after tom.
Regards,
Mike
Please tell me how to render some trees like that. :-[
Trees? No, they were not rendered by Vray. Those were Photoshopped. You need a high resolution jpeg images of trees and background.
