Hi everybody.
I have to do a render of an architectural project.
I have search on the forum, but no answer to my questions…
What is the best way for exterior render ?
I try vray physical cam+vray sun+vray sky, is it correct ? It’s not as I want : it’s too bright so I have to set the camera with extrem parameters, like f-numbers=12 or 16. The shadow don’t seems to be realistics.
I am certainly no render expert (yet ), but I can tell you that when shooting outdoors (in real life) a good rule of thumb is the sunny 16 rule, which says with ISO 100, and a shutter speed of 1/100th (100 in V-Ray), you should expect to use an f stop of around f/16, and this translates quite well in V-Ray. So I don’t think these numbers are extreme, but right in line with what I would expect.
As for your shadows, can you post a pic? Again, I’m not an expert, but I would suggest you use a sun light (place with the command sunlight) as opposed to the default light, and under the Environment option, set your GI (Skylight) to use material type Sky.
if you set the same env settings at the background, than you should see it at the reflections. But if you like to use a HDRI, keep in mind, that the exposure of the image depends on the camera settings. Try a higher intensity of the HDRI (1, 10, 100 , ..) - it should work.
