Hello guys I keep learning how to manage exteriors scenes how my teofas friend saids interiors are more easy to manage, critics and comments are welcome.
http://img40.imageshack.us/img40/893/dayscenecam1farmexps2.jpg
Re: Exterior Render.
I love the glass! Good job! I don’t like the displacement grass. I think the grass are to thick .
Fernando thanks for the comment, what its you advice so I can reached a great displacement grass.
im using the latest version. ![]()
hey david…
el asfalto se ve muy bien… podrias compartir el material?
for the displacement of the grass…
try this… go to the vray for sketchup options, and then to displacement…
there, just modify the two values…
for the one of the left, try something like .8 and for the value of the right go for 800
those are some values that i use… and i think they work fine…
great work ![]()
i agree with fernando and with omar about the glass and the asphalt, they look pretty good, but i think the bamboo plantas edges looks too sharp and the tree behind them is too blurry, also the upper edge of the building is too sharp, and maybe some books on the shelves can give more life to the interior and improve the hole scene, those kind of details always makes the difference, …i know most of the ocations we dont have time for little details, but i think they are worthy…nice job anyway, keep posting bro.
Porsupuesto que si mi estimado te mando el material del asfalto, mas bien es de concreto pero es de buena calidad las texturas!. donde te la mando a tu correo o aqui por el foro?
Teofas thanks for your comments and apriciated your advices, hey for the shelves im was looking for pharmacy products in the warehouse didnt found nothing, does shelves are going to be for medicines.
For the displacement, you can use the Texsplat for the displacement. Depending of the scale, change the size to .05 and change the “interation” to 10. Disable the “use Global” in the displacement option and change the “Edge Length” to 2 or 1. If you want a little bit of more realism, you can use a 2sided material to add translucency to the grass, but this is going to increase the render time. I use 1.5 in for the amount of displacement.
Here is my test
Me gusto mucho tu render se ve muy real, el césped se ve un poco ireal pero de ahà el resto se ve muy bien el cristal le da un toque muy realista! PodrÃas compartir el material de recubrimiento de las paredes? he buscado como Alucobond pero no lo he encontrado. Gracias.
now thats a good explanation and good values for displacement! you are a real master fernando!
Thank Teo, I learn from you guys too.
I apriciated your help Fernando, I will apply does values to my next project, a ver como me va. ![]()
If you want I can give you the material.
will you share the material sir fernando?
I learn a lot from you, your a real master ![]()
Here is the grass material
Hello Fernando, the link for the material its not working ![]()
Mediafire.com seem to be down.
Try this one
Nice, I like. Is the Building in the reflection part of the overall setting? Perhaps reduce the glass reflection just a tad because currently it comes across as realistic but too complex to show the interior of the building nicely.
Actually that is the result that we wanted for this design something abstract, between outside and inside the project. Its a picture behind the camera import a building and make it a box. ![]()
