Exterior rendering - animation
Hi guys. My name is Zorian and I’m using Blender for some amount of time. first Cycles then Corona exporter. Anyway the lastest noncommercial scene I’ve been working on cause a huge issues with exporter so I decided to try a Vray, and the exporter works really faster than unnoficial for Corona - The scene I’m trying to render was exported in 5 minutes in compare to Corona 48h, so the difference is huge.
My problem is, that I’m not sure where I have to connect my hdri image- in the world nodes or create hemilight with attatched texture. Or both?
Try one at a time in small scene, I think the result is the same if you are using V-Ray 3.6. If you are using V-Ray Next then use Hemi light with adaptive dome light option. Maybe adaptive dome light works also with V-Ray 3.6, I dont remember. There are node settings: https://github.com/ChaosGroup/vray_f…_exporter/wiki
Pretty big scene you have :slight_smile:
