Exterior Rendering Tests
Hi, i would like to show you some of my last exterior rendering test, and would be more than happy to hear your comments and suggestion for improvements
for setup, i used vray sun and sky with standard setting, and change the iso from the vraycam to about 65, depending on the scene. Irr+ Bruteforce and gamma 2.2
thanks a lot guys!!!
The subtle dof is lovely - First image is great. The water on the second one is a little off - I think the size of the noise / bumps in it are a little large. Not a huge fan of the colours of the house either but that might be a client thing or you’re matching a photo?
Either way really nice work - far better than my exteriors at the minute :smile:
hi joconnell,thanks for taking time to give me feedback!!!
i think you are right with the second image,i couldnt figure it out by myself whats wrong with that image. the water waves seems to be really to big, i will render it again to see if it looks better. thanks again.
the first two houses where rebuild from pictures i found on the inet, so i also tried to took the original colores…
the third house, was created from cad plans from a friend of mine, who is going to build that house for him and his family. I rendered him out some views to give his family an impression how everything is going to look like…
the goals for this testrenderings were to create myself a template scene for exteriors, so that i can just drag an drop new models in without setting up my renderingsettings and light/material everytime…
thanks again, and best regards from austria
Yeah it seems good - it looks like you were going for the same idea as fekta.studio on here posted - he has a post with some sun / sky tests which were really impressive - yours are definitely headed that direction!
havent seen that thread yet, but i will try if i find it.
when i am ready with testing i am going to post some settings and results
thanks again
Here it is - great bits - http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=41281
thanks alot!!
great grass , and nice green on trees , …hat off
Very nice clean renders..congrats :slight_smile:
