Exterior Scene
this is my first work with Corona. I started using this amazing engine 2 weeks ago and i can´t remember when i´ve been so impressed with a new software ! The inspiration for the scene was a photo from archdaily and i modeled the scene with Sketchup.
The render has potential, but you need to define better the light source. Sky’s doesn’t look fit to image.
Are you using physical cam? Chack the parameters.
Good start.
Some fresnel reflection on the flora would help a lot.
thank you for looking and for suggestions. I will try differently next time. I was using a Vray Camera just because it has the vertical shift parameter. The sky is the same image that i used for Ibl in the environment slot.
For the flora i set the fresnel to 3.
