Hi All,
I made this exterior test, I use a corona Sun with an HDRI on the max enviroment.
I attach the render image and the retouched on post
I think is to much noise comparing the time i spend in it, with others i saw here.
Used PT+HD cahche 10 interpolating samples on light slot.
Cheers,
Try switching to PT+PT, it should do way better…
Thanks keymaster
I will try this, should i give more time to it to render?, i tought that pt+pt compsume more time that Pt+HD cache…
Cheers,
Not always, it is actually faster in exteriors
hi keymaster,
Here i have render the same image with PT+PT, i left it becouse i go out, i dont know the result in about an hour and a half.. any way i think it still a bit noisy for the time it takes.
I will try with the new alpha build.
I have an issue with a I save the image as a JPG, it is saved with crop, not the all image..
Cheers.
