so, we have this, and i will try to make some animation.
i used bidir/VCM method, because with pt+pt and pt+HD animation become flicking. in bidir noise is identical on every frame. only problem - speed of rendering and fireflies, even if i set max sample intensity to 1.0. maybe someone knows how to make rendering faster and remove fireflies. what settings are correct to render animation?
thank you.
all materials are quite simple. no bump, no displace. just diffuse color/bitmap and reflect/refract color
at the moment there are just hdri in environment slot without corona sky, because i want clouds ![]()
also, parsing the scene (5:49) and structure build (3:31) become slow after adding about 20 animated cars (they are summary about 6 millions of triangles). just 5 objects to car (body and 4 instanced wheels), with multimaterial to about 20 simply materials to car without any bump or displace. before that it was about 3 minutes in total. there are about 60 millions of polygons in scene.. so i do not thought that ± 6 millions will play role.
after that i reduced polycount of scene by lowering number of instances in forest, and again saw bug with coronascatter, but now it become on frame wich has been setted in animation. you can see it in first gif.
also i changed algorithm to pt+pt. noise is realy identical. i don`t know why i thought differently oO. but.. in second gif i marked strange place.
you can send me the scene if you like, and I’ll look into it when I get back from siggraph
I have time to prepare the scene until July 5. then I’m leaving for vacation in sunny Kamchatka
Rendering takes that month. I`l came back 3.08.13 and send scene for tests. 15 + PT PT passes for preview take about 1.5 minutes. the rest - about 9 minutes takes scene parsing and structure build. maybe it is possible to make, for example, parsing the scene one time at the start of the rendering? or reduce time for prepare the scene in some other way.
also I will remove trees and the grass, which will not be visible once the camera will be animated.
I tried to do everything neat and simple. but may have missed something somewhere. No one is immune from this.
